Throttle body heater, p1171 and p1174
Old Feb 13, 2015 | 02:50 PM
vishrb's Avatar
Default Throttle body heater, p1171 and p1174
So got the new disco and have started taking care of some issues. Before I could get started I decided to try and clean her up. Went through an automated car wash and a block or so away I got some SES codes. P1171 and P1174. At first no mechanical issues could be noted but later that day I ended up with some coolant coming down to the ground on the drivers side. I popped the hood and noted coolant on top of the valve cover. So I am guessing the throttle body heater seal? Did not note much in the way of build up or anything. I ordered the throttle body kit from roverparts but I think I will do a bypass until it gets here.
Now the p1171 and p1174. Can this be related? I would guess so.
Also should I do the hoses leading to the throttle body heater? If so any idea what size those are?
Old Feb 13, 2015 | 03:52 PM
vishrb's Avatar
also anyway to get this write up with pictures?
https://landroverforums.com/forum/di...57/#post153954
Old Feb 13, 2015 | 03:55 PM
dusty1's Avatar
not likely related
those codes are indicating vacuum leak
Old Feb 13, 2015 | 04:35 PM
vishrb's Avatar
Originally Posted by dusty1
not likely related
Any good idea son how to find the vacuum leak? I did a visual inspection up to the throttle body and it all looked ok. Obviously that is not very scientific.
Old Feb 13, 2015 | 04:44 PM
dusty1's Avatar
you can search on how to do a smoke test. that works for some.
look at the lines from brake booster, that's a good start.
I've had leaks there and an injector leak........both gave me those codes
Old Feb 13, 2015 | 08:49 PM
vishrb's Avatar
Ok, will start in that area. Thanks.
Old Feb 14, 2015 | 07:53 AM
mln01's Avatar
Since your truck's a '99 like mine I'll assume it doesn't have SAI. In that case there should be a small, black plastic cap covering the port near where the brake booster line connects to the intake. The SAI connects to this port on trucks equipped with SAI. The original cap on my truck cracked eventually. Take a look at yours and make sure it's there and intact. See pic.
Old Feb 14, 2015 | 10:00 PM
vishrb's Avatar
I will check to see if I have SAI. It is a 99 but has a 2004 motor in it.
Old Mar 6, 2015 | 01:41 PM
vishrb's Avatar
Got the TB heater gasket all squared away. Time to tackle the vacuum leak. I am going to try the do it yourself smoke test. I will post my results.
Old Mar 7, 2015 | 09:26 AM
ST_Farms's Avatar
Another easy way spray a little starting fluid or brake clean along hoses when it revs up a little theres your leak.
