Throttle Coolant Gasket...Again!
This past weekend, my coolant gasket at the throttle body started leaking. This is the third time in 3 years...just getting ridiculos.
After looking at the configuration...I decided to just run the coolant hose from the reserve tank to the engine (bypassing the flow through the throttle body).
Over the past week, the truck has run great. Have others on the forum used this solution (from frustation with the throttle gaskets)? I live in Atlanta where I don't think cold temperature will be an issue for the throttle body.
i hope you are figuring out that the word again is a trait of LR...Don't ever think if you fix something on these POS will actually hold...or for that matter last...i guess you could them bio degradeable at the rate they fall apart...
abran
Jun 30, 2014 12:43 PM
CANAMDiscovery
Apr 24, 2012 07:19 AM
