Throttle doesn't close all the way
Old Jun 24, 2015 | 06:45 PM
Broken08's Avatar
Default Throttle doesn't close all the way
I have checked and loosened the cables, yes.
If I gently let off the throttle (which I always do since I'm a good, smooth driver) the throttle will stay slightly open. 1100 rpm in neutral. If I stomp on and off again it will settle closed.
Can I increase three return spring pressure?
Old Jun 24, 2015 | 07:05 PM
Kenso's Avatar
Have you tried cleaning the throttle plate and inside the throttle body? If it's dirty/carboned up that might be preventing it from closing fully.
Old Jun 24, 2015 | 07:48 PM
dusty1's Avatar
X2 on the cleaning. I have bought a few used units and they were the same way until I clean them
Old Jun 25, 2015 | 09:16 AM
Broken08's Avatar
yea, i thought that could be a potential issue. I'll try and tear it open soon
Old Jun 25, 2015 | 03:23 PM
OffroadFrance's Avatar
Sounds like the throttle stop gizmo is sticking partially open especially if the cable is returning OK and there some slack there.
Old Jun 26, 2015 | 05:28 AM
disc oh no's Avatar
X3 Clean the throttle plate! This is a common issue on ALL vehicles.
Old Jun 28, 2015 | 04:02 AM
Broken08's Avatar
but when it is closed all the way, there is barely any spring tension on it. I feel as though I'd like to bend the spring to give it a new stop.
Old Jun 28, 2015 | 03:13 PM
disc oh no's Avatar
Are you thinking that maybe the spring is worn out? If so, it may be a better idea to replace it. You DON'T want that to break and cause a wreck!
Old Jun 28, 2015 | 03:29 PM
IMO replace the whole unit as they can't be too expensive. You really don't need a throttle stuck open in an emergency situation ........... terrifying, I can vouch for that.
Just For Fun
Dec 18, 2013 08:22 AM
SenatorPerry
Jul 15, 2013 10:28 AM
drdabbles
Aug 17, 2010 07:37 PM
gsxrgessler
Jan 26, 2008 08:34 PM
tads
Aug 20, 2007 03:41 PM
