Throttle Position Sensor Bolt Size
Old Jan 6, 2018 | 03:00 PM
CollieRover's Avatar
Default Throttle Position Sensor Bolt Size
Has anyone chnaged their TPS recently? I am having a heck of a time finding a socket to fit on to the bolts. It seems to be somewhere in between 5 and 6MM, or 3/16 and a 14.
Am I losing my mind?
Old Jan 6, 2018 | 03:10 PM
I am looking at Rovers North and it says that the bolt is M6 x 25mm but my 6mm socke will not fit. I'm befuddled.
Old Jan 6, 2018 | 03:44 PM
acg's Avatar
acg
The Atlantic British video at 5:56 minute show 5/16" or 8 mm mounting bolts. The 6:52 minute indicate 5.5mm bolts at the bottom holding the throttle heater plate.
Old Jan 6, 2018 | 03:48 PM
I got them off with a random socket of a different design. i am going to head to the store to find a socket that fits or a replacement screw or bolt.
Old Jan 6, 2018 | 03:57 PM
acg's Avatar
acg
If you do not already have one... don't forget you will most likely need a 1/4" socket extension to get to the two 5/16" mounting bolts at the bottom.
This is from my experience a couple of months ago..... I did not have this extension. I ended up taping a screw driver to the slotted head of the socket so that I can turn the bottom bolts.
Old Jan 6, 2018 | 04:04 PM
mln01's Avatar
M6 refers to the thread diameter, not the size of the head.
Old Jan 6, 2018 | 04:19 PM
I brought the bolts to the store, and they are 7/32" heads.
The TPS I got from NAPA is fitting oddly, and the sensor that was on read as a Porsche TPS in Napa's system.
LRD2&ME
May 13, 2019 09:25 PM
keoni004
Dec 15, 2017 03:19 PM
LRD2&ME
Jul 8, 2011 07:16 PM
LRD2&ME
Jul 5, 2011 04:30 PM
rykrover
Mar 2, 2010 06:28 AM
