throttle problem? stuttering.
Please help! I was just about to head out on a road trip and my Disco II all of a sudden started stuttering a bit, still drives, idles fine but can feel loss of power after 1500 rpm. service engine soon light came on, flashes at 1800rpm, stays solid when idle. I checked all hoses, no leaks.
Check those codes but you probably need a tuneup. Use magnacor 8mm wires from Apex performance (http://www.apexperformance.net/CartGenie/prod-1155.htm) or if you cannot afford those go with kingsborne wires. Use decent spark plugs of your choosing.
