Ticking noise need some help
Old Dec 21, 2009 | 09:07 AM
lipadj46's Avatar
Originally Posted by jwood700
I as not aware of oil pump problems with 03... How hard is it to change the oil pump?
An oil pump is a pretty easy fix. But as you will read, you cannot fix the problem but a new oil pump should buy you some time. That is of course if you have an affected engine, have your oil pressure tested.
Old Dec 21, 2009 | 02:42 PM
Bryan H's Avatar
Add one more potential culprit to your list. It could be a slipped cylinder liner. My '03 has a loud knock and it is NOT the oil pump. I've had several people suggest slipped liner and the knock is either the rod contacting the liner or the liner hitting the bottom of the head.
Humdinger
Oct 18, 2016 05:05 PM
TRIARII
Sep 21, 2014 07:25 PM
john65b
Oct 10, 2013 05:00 PM
30more
May 28, 2012 05:01 PM
2003DICSO
Aug 7, 2009 06:13 PM
