Ticking sound coming from top of engine
Old Sep 27, 2012 | 09:24 AM
Timothy Wright's Avatar
how many pounds should I tighten the bolts to?
Old Sep 27, 2012 | 10:04 AM
lr2001silver's Avatar
Banned
Just make sure they are snug and then check them every oil change. 8mm 12point 1/4 drive socket.
Old Sep 27, 2012 | 12:07 PM
I cleaned the connections and it is still running very rough.
I'm going to change out bank 1 sensor 1, unless you have any other thoughts.
Old Sep 27, 2012 | 01:34 PM
jfall's Avatar
Get a scanner.
Read pending codes if any.
Go to scanner live mode
Watch the O2 sensors.
They should go from .1 to .9 volts back and forth.
the two fronts will do this on bank #1 and bank #2.
The 2nd sensors or rear sensors will output a constant voltage depending on how well your catalytic converter is scrubbing.
Old Sep 27, 2012 | 05:40 PM
Originally Posted by jfall
Get a scanner.
Agreed, before throwing parts at it rent a LIVE DATA OBDII scanner, plug it in and watch the O2's, a dead O2 will not change voltage it will hold whatever volts it wants or be very slow to change volts.
A normal working O2 will change voltage every second or so.
Old Oct 1, 2012 | 02:27 PM
I changed bank 1 sensor 1 and codes are cleared and engine is running smooth. Still getting ticking sound from top of engine.
Old Oct 1, 2012 | 02:39 PM
Banned
How did you determine where this tick is coming from?
Old Oct 1, 2012 | 02:55 PM
suzukisam967m's Avatar
just a thought, and I'm no expert, but because you had coolant hose work done, if you have an air bubble or any other coolant issues, and you don't have an UG you could be running warm causing the tick... I only know from experience if your running thin oil and getting hot that will cause it. I have a nasty tick that will show up around 220.. I run around 190 now 195 at the warmest. and she runs like a well oiled machine. didn't know till I plugged up the UG and dropped in a motorad 180.. again I'm a total newbie, just passing on personal experience. and don't trust your idiot stick on the dash it will let you run well over 220 and never budge....
Old Oct 1, 2012 | 04:40 PM
jfall's Avatar
You are probably running Synthetic 0W to 40W oil.
Drain your expensive oil out.
get rid of it.
Don't put synthetic into a big, loose low RPM push rod engine like this.
Engine does not appreciate it.
Any Synthetic I have put in turns BLACK after 1000 miles.
Harms it more than helps it.
Put in Rotella 10W -40W non synthetic.
Put in a good Wix oil filter. Not a Fram or some garbage like that.
I bet the tick goes away.
This is a person who has had rovers since December 1996.
So, don't think I am just telling you this for the fun of it.
Old Oct 2, 2012 | 05:51 AM
drowssap's Avatar
Rotella 15W-40W diesel oil, 10w is to thin.
