Tie rod ends
Old May 19, 2020 | 03:50 PM
zuke's Avatar
Default Tie rod ends
Need to order these from L8. Do you guys replace the rods as well or just the ends?
Old May 19, 2020 | 08:36 PM
Red5's Avatar
I bought those from L8 but found that my OEM (I assume it was original) tie rod had one end that was crimped after it was threaded in so it wasn’t coming out. I didn’t want to replace only one joint so I bought the complete tie rod/drag link set.
Old May 20, 2020 | 02:09 AM
JUKE179r's Avatar
I did the same as @Red5 but went with the Terrafirma set. If anyone else goes this route I'd strongly suggest you clear coat the whole set and tie rods.
Old May 20, 2020 | 05:41 PM
HuskerRover's Avatar
Just replaced the track rod from lk8. I won't be doing any serious off roaming so went with the stock replacement. Mine were probably original so the crimped end made it easy to justify the whole rod with both ends. Also replaced the dampener as it looked crusty af.
sooooo much smoother driving now.
jbullock78
Feb 4, 2021 07:15 PM
Kevin Rhodes
Jul 19, 2016 03:02 PM
TOM R
May 17, 2013 01:58 PM
collin Barrows
Jul 20, 2012 06:32 AM
ebg18t
Apr 25, 2012 08:18 PM
