tie rod ends
#21
#22
on
Yes they have tie rod ends, not on the shelf, but overnight, I just paid for mine, will be here tomorrow. I got under the truck this morning and at least one it completly gone, I can move the thing up and down there is so much slack. I'm just doing them all so one trip to allignment shop. As for my concern with the grease nipples getting damaged, they all face up except the one on the steering box arm , which is higher up, so I don't think I'll have a problem. Thats what I get for asking dumb questions before I even look closely.http://shop.advanceautoparts.com/web...S_446420294___
#24
#28
tweak, if you want to align the toe-in yourself, get two pieces of 1" flat stock banding (stiff) & make a telescopic piece to fit between wheel edges.
The manual said 0"--1/4" TOE OUT
I pulled into my driveway straight (don't worry about the steering wheel angle.)
I set mine for 1/8" toe out - then drove around the block & straight again.
I then adjusted the drag link to align my steering wheel.
Had it checked @ alignment shop a week later (new tires) & it was good.
luck,greg
luck,greg
#30
http://www.saeproducts.com/flush-grease-fittings.html
1998DiscoverySE
02-10-2012 11:00 AM
