tightening emergency brake?
Old Sep 27, 2008 | 11:26 PM
detcord's Avatar
Default tightening emergency brake?
anyone know of a guide that explains how to tighten up the ebrake on a 99 d2? i just got a brake job and forgot to tell them to tighten it up, it doesnt grab until the last 2 clicks i want it to grab earlier.
Old Sep 28, 2008 | 03:02 AM
Urban Panzer's Avatar
Default RE: tightening emergency brake?
Climb underneath and look at the large drum on the back of the transfer case,in / on the bottom of it on the oppsite side to the driveshaft, you will see a 17mm bolt head, thats the adjuster.
Park the vehicle on level ground with handbrake off (chock the wheels). You will be able to slightly turn the drum by hand,tighten the adjuster till the drum is locked and you cannot move it anymore, then back it of again 1-1/5 turns.
Check the operation of the handbrake, if its still to loose (too many clicks), tighten it a bit more at a time till its good, BUT always make sure the drum can move by hand when the handbrake is off.
It should hold the vehicle after the first 3 or 4 clicks.
Old Sep 29, 2008 | 02:10 AM
detcord's Avatar
worked perfect, thanks!
Old Sep 29, 2008 | 08:26 AM
your welcome
rmschmidt
Apr 28, 2010 01:19 PM
ALEXAN
Sep 28, 2009 11:24 PM
starcraft
Feb 10, 2009 04:25 PM
co556guy
Feb 4, 2009 08:01 PM
dcnellie
Oct 31, 2007 09:14 PM
