Time for New Cats
Time for New Cats
I'm in search of replacement Cats for my 1998 Disco1 w/118k on the ticker. I've just gotten the P0420 code and so far I have addressed (months ago just for mant/upkeep reasons) the following prior to the recent CEL coming on for the code:
1. New Magnacor Wires
2. New Bosch Plugs
3. Replaced all (4) O2 sensors
4. Fixed the Coolant leak from the front cover
5. Fixed the oil leak from the pressure sensor
Also, before I changed the Wires, Plugs and sensors I did a Sea foam treatment. No CEL light was popped at this time (only after the O2 sensor replacement didthe CELcome on and after about 100mi of normal driving).Which -to me- means that the sensors are now working correctly and telling me that I need to replace the CAT's. No other codes are showing or Pending codes. All Of the EVAP status are in the ready state on the reader. However I have also been noticing the following since the CEL light came on:
1. It takes alittle longer to shift from 2nd to 3rd
2. Reduction in gas milage.
My Discois running great and holding all of it's fluids...(yeah if you can believe it!). No Noises or Leaks coming from the Ex. Sys. I use only premuim gas and synthic blend oil.
Bottom Line........
What Weld in placeOEM or equiv. Cat's do I need?
Anyone have a Make and Model numbers they can recommend?
Thanks guys.
2. New Bosch Plugs
Bottom Line........
Thanks guys.
RE: Time for New Cats
Spike555,
The CEL came on after the first 100Mi's long ago. Ive logged in dozens of tanks and a few ECU resets. The same code keeps coming up.
I'm just now getting to the point of having some time on my hands to strap on the old Vader helmet and go to town!
Ohyeah...I have to put the Disco threw PA inspection next month.
I don't know if linking to other forums is frowned upon here, but discoweb.org has a writeup on replacing cats on their front page, with part #'s etc.
These are the cats he listed, I have no personal experience replacing cats, just linking what i read elsewhere
[*]MagnaFlow 94105CA[*]MagnaFlow 94005CA[*]Catco 2405[*]Catco 6905[*]Bearcat 2.25 w/o air[*]Maremont 38503
Dave
Dave
All,
I've seen this post and it is helpful, I was just looking for the Personal exp. I just want to make sure I get the right size (ID/OD, 3way or 2way, ton rating etc.). If I remember that post is also for a '99 Disco II. I wasn't sure if there was anything different.
Skibum232
11-20-2007 05:46 PM
