Time for New Cats
Old Sep 21, 2008 | 10:08 AM
Jrock's Avatar
Default Time for New Cats
I'm in search of replacement Cats for my 1998 Disco1 w/118k on the ticker. I've just gotten the P0420 code and so far I have addressed (months ago just for mant/upkeep reasons) the following prior to the recent CEL coming on for the code:
1. New Magnacor Wires
2. New Bosch Plugs
3. Replaced all (4) O2 sensors
4. Fixed the Coolant leak from the front cover
5. Fixed the oil leak from the pressure sensor
Also, before I changed the Wires, Plugs and sensors I did a Sea foam treatment. No CEL light was popped at this time (only after the O2 sensor replacement didthe CELcome on and after about 100mi of normal driving).Which -to me- means that the sensors are now working correctly and telling me that I need to replace the CAT's. No other codes are showing or Pending codes. All Of the EVAP status are in the ready state on the reader. However I have also been noticing the following since the CEL light came on:
1. It takes alittle longer to shift from 2nd to 3rd
2. Reduction in gas milage.
My Discois running great and holding all of it's fluids...(yeah if you can believe it!). No Noises or Leaks coming from the Ex. Sys. I use only premuim gas and synthic blend oil.
Bottom Line........
What Weld in placeOEM or equiv. Cat's do I need?
Anyone have a Make and Model numbers they can recommend?
Thanks guys.
Old Sep 21, 2008 | 01:52 PM
Default RE: Time for New Cats
I would wait alittle longer, the ECU has to remap for the new O2's. It is very common for reduced MPG after new O2's are installed.
General rule of thumb is 3 tanks of gas to remap the ECU.
Once you start your 4th tank then reset the light and wait and see.
Old Sep 21, 2008 | 02:04 PM
sdsilvere38's Avatar
Search ebay for universal cat converters. I bought a pair of new, Carsound cats for $110 each for my BMW 740il and they work great!
Old Sep 21, 2008 | 02:21 PM
Jrock's Avatar
Spike555,
The CEL came on after the first 100Mi's long ago. Ive logged in dozens of tanks and a few ECU resets. The same code keeps coming up.
I'm just now getting to the point of having some time on my hands to strap on the old Vader helmet and go to town!
Ohyeah...I have to put the Disco threw PA inspection next month.
Old Sep 21, 2008 | 02:39 PM
Ok, I didnt realize it had been that long ago.
Go for it then.
Old Sep 21, 2008 | 02:42 PM
tacomadave's Avatar
I don't know if linking to other forums is frowned upon here, but discoweb.org has a writeup on replacing cats on their front page, with part #'s etc.
These are the cats he listed, I have no personal experience replacing cats, just linking what i read elsewhere
[*]MagnaFlow 94105CA[*]MagnaFlow 94005CA[*]Catco 2405[*]Catco 6905[*]Bearcat 2.25 w/o air[*]Maremont 38503
Dave
Old Sep 21, 2008 | 02:53 PM
No help from anywhere is frowned upon. As long as it is helpful and doesnt talk down to someone to mcuh or have cuseing and searing we dont care where it comes from.
I referance dweb quit a bit my self.
Old Sep 21, 2008 | 03:10 PM
Jrock's Avatar
All,
I've seen this post and it is helpful, I was just looking for the Personal exp. I just want to make sure I get the right size (ID/OD, 3way or 2way, ton rating etc.). If I remember that post is also for a '99 Disco II. I wasn't sure if there was anything different.
Fenix
Mar 22, 2016 10:16 AM
slanginsanjuan
Apr 13, 2012 01:58 PM
fern540
Mar 2, 2012 08:52 PM
gmscando
Mar 28, 2011 11:51 PM
Skibum232
Nov 20, 2007 05:46 PM
