Timing chain interval?
I have a 2004 D2 and the timing chain/oil pump were changed about 65k miles ago at 100k miles. The chain was pretty bad according to my mechanic. When should I be planning another change?
If the previous owner neglected maintenance like my truck, around 100k-150k miles. My timing chain was stretched past spec at 118k. Compared with the post above, it really shows the importance of a good maintenance schedule
Chains will go a very long time without failing, but they do stretch. Even with good oil and OE chains, there will probably be enough stretch in the chain by 100,000 miles to have a (slightly) noticeable affect on power. I wouldn’t take it apart to replace the chain at that point, but if I had the cover off for another reason I’d change it.
