Timing Cover Bolt Confusion
Old Mar 12, 2017 | 05:05 PM
robert.juric's Avatar
Default Timing Cover Bolt Confusion
So I replaced the timing cover (again) and I was reading the rave upon reassembly and confused myself. First, it said that 9 bolts secured the cover to the block. I only counted 8 that went though the cover to secure to the block. What it called #9 was one of the water pump bolts that didn't go through.
Then I found one opening that I can't remember what went there.
Also I didn't put these bolts in with loctite. Would it mess the gasket up if I remove one at a time to apply loctite and then torque back?
Old Mar 12, 2017 | 07:59 PM
94svt50's Avatar
There are 9 bolts that go through to block. They have a larger head size and a couple of them go through water pump into block. I don't see why you need lock thread? Picture in rave is off. The hole with ? Goes through to block. The right most two holes in pump go to block if I remember correctly. And 1 more left lower area
Old Mar 12, 2017 | 08:24 PM
OverRover's Avatar
I think this will get you sorted. It better because all the ARROWS made me tired!
Old Mar 12, 2017 | 09:19 PM
That top one with the arrows cleared things up. I must be missing a long bolt...
Old Mar 13, 2017 | 09:36 AM
Do one of the bolts secure a bracket for what looks like oil pressure switch? If so does anyone remember which one?
Old Mar 13, 2017 | 09:57 AM
abran's Avatar
Short bolt does.
Old Mar 13, 2017 | 10:39 AM
Ok, well given the previous modification to the front cover, I'm wondering if they put the bracket on a different bolt. I'm not sure where this *should* be bolted up to.
I found the original dissaembly picture. Does this look correct or no?
Old Mar 13, 2017 | 10:56 AM
abran's Avatar
Bolt hole to the left(looking at cover) from the camshaft sensor hole. It takes a short bolt 11mm.
Old Mar 13, 2017 | 12:16 PM
Just to make sure I'm looking at this right:
Old Mar 13, 2017 | 12:28 PM
OverRover's Avatar
Yes, that's where the bracket mounts.
