Timing cover oil pump clearance
Does anyone have what the oil pump clearances are in the timing cover? I have a couple of covers with light scoring but trying to ensure I can reuse at least one of them. Nothing in the RAVE.
Edit: found the Overhaul manual below but I thought I remember seeing a measurement between the outer gear and the bore the gears sit in.
https://landroverforums.com/forum/at...ng-4th-ed-.pdf
