Timing cover oil pump clearance
Old Dec 3, 2022 | 05:03 PM
zski128's Avatar
Default Timing cover oil pump clearance
Does anyone have what the oil pump clearances are in the timing cover? I have a couple of covers with light scoring but trying to ensure I can reuse at least one of them. Nothing in the RAVE.
Edit: found the Overhaul manual below but I thought I remember seeing a measurement between the outer gear and the bore the gears sit in.
https://landroverforums.com/forum/at...ng-4th-ed-.pdf
Old Dec 4, 2022 | 02:26 PM
XRAD's Avatar
axial max between cover and rotors: .1mm
radial max between rotors: .25mm
source: lloyd's tuning and modifying the rover v8 2019 ed
It is advised that with any scoring of cover, replace the cover...
blakslee720
Dec 11, 2019 10:01 AM
Charlie_V
Apr 3, 2016 09:01 PM
Amanda Bass
Feb 19, 2016 06:04 PM
Moxierover
Dec 4, 2012 06:24 PM
shanechevelle
Nov 4, 2011 06:29 AM
