Tip for replacing bushings on watts linkage
Old May 7, 2024 | 04:46 PM
Brandon318's Avatar
Default Tip for replacing bushings on watts linkage
Hey all! Just pressed these bushings in on the watts linkage and will hopefully save someone a bit of time by letting ya know:
For the two smaller bushings, a 12-point 1-13/16” socket fits exactly over the rubber boot but also still presses firmly against the housing to press the bushing in properly. Any smaller and the socket will pinch and tear the boot. Any larger and it won’t press evenly against the shell.
For the center bushing, use a 29mm 12-point socket to achieve the same result.
A thin smear of grease inside the housing works well to aid in pressing them in.
Hope that helps!
Old May 7, 2024 | 11:35 PM
Harvlr's Avatar
Thanks for that info Brandon.
zuke
Mar 5, 2020 04:50 AM
vette427sbc
Sep 9, 2014 04:40 PM
Rover Newbie
Jul 17, 2014 07:47 AM
CANAMDiscovery
Oct 16, 2012 04:48 PM
