Tips on degreasing an engine
Old Sep 29, 2008 | 09:41 PM
theworks001's Avatar
Default Tips on degreasing an engine
Are there any tips on degreasing an engine?? What do you have to cover when doing it??
thanks
Old Sep 29, 2008 | 10:14 PM
Default RE: Tips on degreasing an engine
You dont have to cover anything. It is best done at the DIY carwash so that the grease and oil can be properly disposed of.
Just dont use the high pressure, use the low pressure wand. If you can bring your ramps so that you can clean the underside too.
Let the engine cool for 5-10 min before you start.
Old Sep 30, 2008 | 02:24 AM
mrcrptguy's Avatar
I would double check that your computer is properly sealed, mine is located on the passenger side fender under the hood near the firewall.I sat at the carwash for over an hour with my Disco unable to start. I found that the inner most plug was not completely water tight and i had no spark. I removed the plug, dried it out and all was fine again.
mwohl
Aug 26, 2016 08:23 PM
Dan87GT
Sep 19, 2011 11:26 AM
buick215
Nov 23, 2010 10:29 AM
lipadj46
May 20, 2009 11:16 PM
7tiger7
Dec 30, 2004 04:27 PM
