Tire pressure for bigger tires
Old Feb 24, 2018 | 06:05 AM
Fastercat's Avatar
Default Tire pressure for bigger tires
What air pressure are you guys running with your oversized tires? Do we really need that much more pressure in the rear tires as opposed to the front? In the past I’ve always been able to run much lower pressure on over sized tires on the street. Like 20ish psi don’t and back. Have load range e tires so good side walls.
Old Feb 24, 2018 | 07:35 AM
LR03NJ's Avatar
I go around 36 with LT tires. And seem fine to me. You can follow the pressure setting on the doors. To much pressure on larger tires will rattle your brain.
Old Feb 24, 2018 | 09:19 AM
Alex_M's Avatar
I run 47 lbs on 10 ply 285/75r16s.
Old Feb 24, 2018 | 09:28 AM
coop74's Avatar
20 lbs of pressure in most tires at highway speeds is a recipe for disaster... There are two things you can do. The first, which takes a bit of time, is to measure your tire pressure cold. Run the truck at speed long enough to get the temps up and see how much the pressure changes. Ideal is like 10% increase. So if you are at 20 cold it should be 22 at operating temps.
The second way is to check with your tire mfg and see if they have a chart for pressures which are normally based on weight. It will tell you an optimum pressure (again cold) to set the tire at. Some times you have to dig to find it however or call their customer support line.
Closing thought, this pressure is for operating speeds not for offroad...
Old Feb 24, 2018 | 05:38 PM
Fastercat's Avatar
Well I dropped the fronts down to 30, and the tears to 37. Huge ride improvement. I may go lower in the back yet. Can anyone tell me why they spec higher pressure in the rear over the front? Is it for towing?
Old Feb 24, 2018 | 07:31 PM
LR03NJ's Avatar
Yup. Just about right.
Old Feb 24, 2018 | 07:37 PM
coop74's Avatar
it is because that is the max and because the Disco rear hatch area is meant a carrying space for a pretty good amount of weight. In one of the books i have on them somewhere it gives unladen pressures which are much lower in the rear
Old Feb 26, 2018 | 12:32 PM
Big Jim Swade's Avatar
I seldom carry anything in the back so I run 32 front and rear. Rides pretty well at those pressures.
Old Feb 26, 2018 | 12:56 PM
JUKE179r's Avatar
Same here with 32 all around.
Unless my mother-in-law is in the backseat then I'll bump up the rear TP to 46.
Old Feb 26, 2018 | 01:27 PM
Best4x4's Avatar
All tires/sizes are different & so are the vehicles they’re installed on. Discount Tire always over inflates my tires. I prefer to come home & do a chalk test. Start aired up & go back n forth over the chalk until all of the tread is covered by the chalk = tires are aired up properly per your application. Once you do it, you can keep a record of the Front/Rear PSI & then quickly air them up in the future.
Learned that back in my Jeep days as everyones idea of proper PSI was never correct due to equipment/tires. Chalk test will without a doubt get you to the proper PSI.
