Tire Pressure - Non-Stock Tires
I upgraded to LT 275/65/R18 Cooper A/T tires a while back. I was getting ready for a long road trip and realized I didn't know the proper tire pressure for these beasts.
So do I use the formula on the door placard which is for a different size tire or do I inflate to another value. The interwebs are all over the place with recommendations.
I'd do a chalk test. Every upgraded/modified 4x4 will be different and the sticker in the door is totally meaningless unless it's the OEM tire size. I ran 26PSI for example in both my 05 Jeep Wrangler Rubicon's with 33inch M/T's, which was nothing like the door sticker had listed for the stock 31inch tires.
whowa004 (05-13-2020)
No problem, yeah I took a lot of heat for running under 30PSI on my Jeep's from so called fellow Jeepers. I also got close to 50K out of a set of M/T's so I'm not complaining. I told all those Jeep owners how a chalk test works, and they just looked at me. Once you get a nice even amount of chalk across the tire = you have the proper PSI for your vehicles weight/config for on road travel/use. Off road of coarse = air down if needed for maximum flotation/traction.
YouTube videos out there explain it pretty well. You use chalk on your tires and drive it for a bit to see where the chalk rubs off. By inspecting the chalk you can see whether to increase or decrease pressure.
@Best4x4 should this be done when the tires are warm or cold? Finding conflicting info on the interwebs.
Best4x4 (05-14-2020)
