Tire upgrade ?
Old Mar 4, 2012 | 11:19 PM
Maurice Carter's Avatar
4th Gear
Default Tire upgrade ?
Upgrading my tires. 00 Disco2 OEM size is 255/65/16, Can I use 245/75/16 tire? or a 245/70/16.? Wondering about claerance issues. thanks.
Old Mar 4, 2012 | 11:57 PM
bosshogt's Avatar
It depends if you have a lift? With a 2" lift you could probably fit those tires.
I have a OME 2" lift with Good year Duratracs 265/70/16's. They do not rub, but you will loose 2/3 mpg and torq with that tire size. To get it back you would have to upgrade to 4:11 gears.
Old Mar 5, 2012 | 08:04 AM
jafir's Avatar
245/75/16 should fit stock on a D2, most of the time... It's only about an inch bigger, so that's half an inch on each from center.
Old Mar 5, 2012 | 08:52 AM
kenk's Avatar
I would imagine a 245/75 would clear fine. I am running 265/75 with only a trimmed airdam and adjusted steering stops.
A size you may want to consider is a 255/70, as wide as stock, but about an inch bigger.
And like bosshog says- the bigger you go, the more mpg you will loose. I get a 3mpg difference between my '98 and my '04( 04 worse=bigger tires)
Old Mar 5, 2012 | 11:04 AM
00rove's Avatar
6th Gear
Sorry to buf, but what about an 18' tire. I have the factory 18's on my 00' disco II
John Frederick
Mar 25, 2014 12:00 PM
deoxford
Apr 28, 2012 08:55 PM
Maurice Carter
Mar 2, 2012 02:26 PM
Outback Jim
Dec 5, 2011 06:55 PM
LR3invancouver
Apr 14, 2005 07:25 PM
