Tire/Wheel Size 2003 Discovery
Old Nov 28, 2010 | 11:20 AM
LR03NJ's Avatar
Originally Posted by DiscoRover007
What bolt pattern and offset and width would I need for 16's? There was no particular reason for the 15's it's just that I saw a decent deal going for 15 inch wheels.
Here is a reference about your inquiry
LINK
Old Nov 28, 2010 | 12:16 PM
tweakrover's Avatar
there is no point in even looking for a 15" rim, one you probably won't be able to find the bolt pattern, two you can find alot better tires for 16" rims (they don't make LT tires in 15"), and three you can find stock 16" on craigslist all day long for under $200(all four, with tires if you are lucky).
Old Dec 15, 2010 | 04:54 AM
98xc800's Avatar
I have had 15" wheels with 31x 10.50 ProComp X-Terrains on my DII for about 2 1/2 years. They are BMW 6.5" wide steelies from a 5 series. The BMW uses 12mm studs, so the holes needed to be enlarged for the LR 14mm studs. The wheels clear the brakes fine, but the rear brake shields needed to be removed.
I tried several GM 4 3/4"x5 wheels, but none are close to working.
tnerb33
Jul 11, 2015 01:55 PM
Harvey Swift
Feb 27, 2014 08:40 PM
RYAN3326
Jan 25, 2013 02:11 PM
FlyingZebra34
Aug 31, 2012 07:33 PM
kclandrover
Tires
Oct 13, 2007 03:33 PM
