Toddco CDL conversion kit
Old May 26, 2014 | 12:15 AM
jwigum's Avatar
Default Toddco CDL conversion kit
Anyone know the story on the Toddco CDL conversion kit?
It states "Convert your non locking Discovery II transfer case to a locking differential with this kit. The kit is a complete bolt in kit, can be installed without removing the transfer case from the vehicle. This kit comes with a $75.00 core charge. You will recieve a return shipper label to return your exsisting non CDL unit."
If you're not removing the transfer case from the vehicle, and it has a core charge... Is this just a transfer case nose and replacement shifting mechanism?
Old May 26, 2014 | 12:17 AM
Dane!'s Avatar
Yep. Its just the front output. 400$ seems steep, I dunno though. As paul grant or someone if they have an lt230.
Old May 26, 2014 | 12:30 AM
jwigum's Avatar
That was my thought as well. While you're rolling the dice, it looks like locking transfer cases and shifter packages on eBay are around $3-400(and then you have a backup transfer case when you're done).
Thanks!
Old May 26, 2014 | 12:52 AM
Dane!'s Avatar
Yeah, but you can just swap the output bearing and you'd be fine.
Old May 26, 2014 | 01:35 AM
acg's Avatar
acg
To give you an idea.... I bought an entire 2004 transfer case from a local wrecker for $400. I transplanted the front output assembly and sold the transfer case for $250. Perhaps I was lucky.... but it worked out well for me.
Old May 26, 2014 | 09:02 AM
Lowest Bidder's Avatar
If you do the swap without removing the transfer case (and even if you do take it out), make sure not to pull on the hi-lo shifter fork as you pull on the old front housing, or to remove the spring loaded hi-lo lever indexer on the side of the t-case near the rear output shaft. If you don't, the small ball bearing will be pushed inside and it's gonna be a bitch to get out of there. I had to remove the rear output cover and redo both gaskets.
Old May 26, 2014 | 10:40 AM
RoverMasterTech's Avatar
I can sell you a whole cdl box for that much
turbodave
Mar 29, 2019 07:22 AM
DustyLBottoms
Aug 11, 2015 07:21 AM
Bostonc16
Mar 7, 2015 10:32 AM
Micko
Sep 28, 2014 02:48 PM
burn1nator
Jun 2, 2014 05:17 PM
