Toddco spacers
Old Dec 16, 2008 | 05:21 PM
malmberg's Avatar
Default Toddco spacers
After my lift I am not level and was told to either use isolators or spacers. I was looking at toddcosuspensions.com and found a set of spacers that look like they will do the job. I was wondering if anyone has used or heard of this place. I was also wondering which would be the best way to level it out. Im not sure if spacers or isolators would be better. I am leaning towards spacers but open to suggestions. Thank you all.
2000 disco 2
Old Dec 16, 2008 | 06:08 PM
Default RE: Toddco spacers
I cant say which to use, but toddco is aVERY reputable place and is one of the top names in lifts.
Old Dec 16, 2008 | 07:17 PM
How much is your suspension? If new, did you check to make sure the correct spring, "A" was used on the drivers side.
I am using the Isolators, 1 0r 2 can be used on a spring depending on how much extra lift was needed.
Old Dec 16, 2008 | 07:31 PM
malmberg's Avatar
well i have an 1 1/2" difference between the fromt and back. Is that too big for the isolator spring. Toddco has 1, 1.5, and 2" spacers. Or will this compromise the suspension. I did make sure to use a for the driver side and b for the passenger. It is b/c the 751s without any extra weight in front gave me a little over 3".
Old Dec 17, 2008 | 10:16 AM
"YUP", too big for the small spacers. Strange, I can't remember ever hearing of anyone having this problem after installing your combination of OME coils, OH WELL.
Old Dec 17, 2008 | 05:50 PM
malmberg's Avatar
I think that if I would have went with the 763s in the rear instead of the 762s that it would be close. But then I would have a pretty harsh ride I am sure.
1961 Lincoln
Mar 8, 2024 07:18 AM
6ta1
Mar 18, 2010 06:19 PM
starrock
Mar 4, 2010 08:09 AM
1961 Lincoln
Feb 1, 2010 12:49 PM
tjjolle
Member Group And Special Buys
Dec 20, 2008 12:03 PM
