Tongue Weight???
Old Apr 21, 2009 | 02:09 PM
RjBu's Avatar
Default Tongue Weight???
Hey guys,
I am running a 2000 DII named Lindy and was hoping that you could clear up some questions i had... So i want to get one of those hitch mounted dual motorcycle ramps... Their max load is 800lbs but the tongue max is 550lbs... Is there a way to get around this (Other than a class 4)? Is it the hitch itself or the suspension? The two bike would put it in the neighborhood of 720lbs???
Thoughts?
Old Apr 21, 2009 | 03:07 PM
okdiscoguy's Avatar
I have seen someone with this setup. They added airbags to the rear coils. Not sure what the hitch is rated for, but I know the suspension won't handle it. The airbags obviously won't work if you already have air suspension.
Old Apr 21, 2009 | 03:22 PM
I would suggest 2 things, first weigh the tongue when loaded so you know for sure and consider getting rid of your weak/tired springs and shock, install a good set of OME shocks and coils and you won't have any issues.
sailorcolin
Feb 1, 2008 02:55 PM
DiscoIIRoop
Jan 28, 2008 07:22 PM
jdelp
Jan 15, 2008 08:09 PM
INTENSE1
Nov 28, 2007 06:25 PM
weatherman
May 3, 2007 05:12 PM
