Too much timing chain play?
Old Apr 2, 2012 | 02:32 PM
discofrost's Avatar
4wd High
Default Too much timing chain play?
Hello,
What do you think is this too much play in the timing chain? Or is this pretty normal for a 200K mile Discovery II?
VIDEO0048.mp4 - YouTube
Thanks
Old Apr 2, 2012 | 03:19 PM
Jared9220's Avatar
To answer your questions. Yes and Yes. That is a lot of play in the timing chain, but with 200k on the engine I would expect that. The chain and sprockets are only about $100 bucks so I would change it while you are there.
I changed my timing chain about a month ago and it looked almost just like that. I only had 100k on the engine, but I went ahead and ordered a new one. After putting the new chain on the difference was obvious and there was almost no play in the new chain at all.
Also, That ticking noise the old chain makes when you mess with the slack will not be there with the new chain.
Old Apr 2, 2012 | 04:56 PM
discofrost's Avatar
4wd High
Thanks for the advice. I'll replace it then. At the risk of sounding lazy for not digging through the tech posts where did you order yours from?
Old Apr 2, 2012 | 05:27 PM
CANAMDiscovery's Avatar
Can never go wrong with the guys at Atlantic British.
Old Apr 2, 2012 | 05:32 PM
Jared9220's Avatar
I bought the timing chain kit from AtlanticBritish.com
I have some pictures and info in a thread I did a while back."Doing a major 100k service" and page 6 is the timing chain stuff.
Too much timing chain play?-100_1907.jpgToo much timing chain play?-100_1909.jpg
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
DooDer
Jan 1, 2010 02:26 PM
Kraftyz51
Oct 21, 2007 10:25 AM
tap121
Apr 10, 2007 07:35 PM
