too much tire???
Old Jun 16, 2012 | 08:25 AM
autoaddict's Avatar
Default too much tire???
OK so I've been doing a lot of research into a/t tires for my discoII, and the tires I've settled on are Goodyear wrangler dura tracs. The question I have for the forum is these tires only come in select sizes and start at 275/65 in 18" which works out to 32" diameter and 9" tread width. Is this too much tire for my truck in stock form? Thanks.
Old Jun 16, 2012 | 09:11 AM
I have a few friends that have that set up and they love it. You will though, loose a little MPG and torque, the ride will be outstanding and you will need a small lift.
If you have any questions, give me a shout.
Old Jun 16, 2012 | 09:51 AM
kenk's Avatar
I run 265/75/16 on a stock set up, which is roughly the same diameter. I wouldn't be surprised, almost bet on actually, you would have to trim the front airdam and adjust the steering stops.
And you will loose a little mpg, and not be able to pull hills as effortlessly.
Old Jun 16, 2012 | 04:33 PM
autoaddict's Avatar
cool...thanks guys, I'm not totally against trimming if it doesn't look like ****...really want to get these street sneakers off!! Running toyo verado 255/55.
blackcloud
Feb 6, 2011 01:21 PM
Aj6543
Nov 10, 2010 10:41 PM
began
Nov 23, 2008 08:59 AM
Kraftyz51
Oct 21, 2007 10:25 AM
tap121
Apr 10, 2007 07:35 PM
