Took the valve covers off...how bad is this?
Rosslato (02-12-2021)
Mine were worse. Remove the rocker shafts, spray with oven cleaner, scrub clean. Make sure the rockers move easily - shift them over and use a scotch brite on the shaft. Use a hose nozzle to clean passages in the rocker shafts. Blow dry and coat with engine oil. use a wire on the oil passages in the block to make sure they are clear. Reinstall properly.
Ian Mitchell (05-25-2019)
