Top end engine rebuild w/ pics and video
Old Feb 25, 2015 | 10:44 AM
2003DiscoAZ's Avatar
Default Engine rebuild
The goal is to bring the engine to a reliable state capable of daily driver duties and family outings. Yes, the head gasket is one of the items that will be replaced along with resurfacing the heads and doing a valve job. Would you suggest that I replaced any other components? Other parts for replacement are listed below.
Radiator
Water pump
Thermostat (low temp variation)
Originally Posted by drowssap
what is your ultimate goal here to replace the heads gasket?
Old Feb 26, 2015 | 05:23 AM
dgi 07's Avatar
You want reliable daily driver..... all aluminum radiator, in line thermo mod, electric fan.
Old Feb 26, 2015 | 03:33 PM
Broken08's Avatar
What is the inline termo mod? Is there a different one to get? How is it modified?
Old Feb 26, 2015 | 04:00 PM
dusty1's Avatar
meaning get rid of the bypass and put a traditional stat in an inline housing
Old Mar 2, 2015 | 11:20 PM
Default Help
I have managed to strip the head bolt on the passenger side closest to the firewall (the pain in the *** one to remove). I'm afraid I stripped it pretty good using a 1/4 inch 5/8 socket and a huge breaker bar, with a wobble extension. Not sure how to address this new issue, any takers? (video to come soon)
Old Mar 2, 2015 | 11:24 PM
I'm thinking about trying one of these to remove it
Old Mar 3, 2015 | 06:13 AM
dusty1's Avatar
Upon removal,Did you start with that bolt?
You should have, but if not put some others back to relieve pressure, then use whatever striped out nut tool. That ^ thing looks promising
Old Mar 3, 2015 | 07:25 AM
drowssap's Avatar
as stated before you should un-torque the head, working from the outside in. But as stated install some bolts and snug them down then hammer a 6 point metric socket onto the head bolt and remove it.
Old Mar 4, 2015 | 01:02 AM
Default Removing head bolts
Worked like a charm, fellow forum members who are tackling this job do yourself a favor and head over to Sears and pickup a craftsman turbo socket!!!!
This thing took the head bolt rite off!
Old Mar 4, 2015 | 11:09 AM
sdhow's Avatar
Default Turbo socket?
I don't see the compressor...and where do the exhaust gases enter?
