Top end engine rebuild w/ pics and video
The goal is to bring the engine to a reliable state capable of daily driver duties and family outings. Yes, the head gasket is one of the items that will be replaced along with resurfacing the heads and doing a valve job. Would you suggest that I replaced any other components? Other parts for replacement are listed below.
Radiator
Water pump
Thermostat (low temp variation)
Radiator
Water pump
What is the inline termo mod? Is there a different one to get? How is it modified?
I have managed to strip the head bolt on the passenger side closest to the firewall (the pain in the *** one to remove). I'm afraid I stripped it pretty good using a 1/4 inch 5/8 socket and a huge breaker bar, with a wobble extension. Not sure how to address this new issue, any takers? (video to come soon)
as stated before you should un-torque the head, working from the outside in. But as stated install some bolts and snug them down then hammer a 6 point metric socket onto the head bolt and remove it.
This thing took the head bolt rite off!
