Top end rebuild problem.
Old Jul 27, 2018 | 04:57 PM
The Deputy's Avatar
While removing the engine in my wife's 03, l found the knock sensor wire completely smashed/grounded between the P/S bracket and head...and it didn't have any codes (besides a SAI system code, which was related to a manifold check valve issue) or misfires.
Actually ran pretty good for an engine with three slipped liners, blown head gasket (external) and no oil pressure...go figure...lol.
​​​​​​​ Brian.
Old Jul 27, 2018 | 05:18 PM
No Doubt's Avatar
Originally Posted by 328Driver
Doing a quick look this morning and the wire to the knock sensor on the drivers side has been somewhat melted on the exhaust manifold. That would be bank 1. Could a bad wire to a knock sensor cause my problem? The misfires and o2 are all on that side.
Pretty small chance of that.
Check your spark plugs for signs of oil or coolant.
Old Jul 27, 2018 | 07:56 PM
328Driver's Avatar
Unplugged the wire so I could pull it up to see the damage. Looks like the wire wasn't breached at all. Taped up the worn areas and plugged it back to the knock sensor. Now all the engine codes cleared. O2 bank 1 sensor 1 came back up. Idles smooth again. I'm at a loss. Can cylinders misfire just every now and then? I doubt it's a coil/plug/wire since it ran smooth for a week after the rebuild and today putting 20 hard miles on it. Before ya'll give me crap I'm going to put in new O2's. Thinking a reset of the adaptive settings are my problem.
Old Jul 30, 2018 | 10:38 PM
328Driver's Avatar
So to wrap it up I put in new O2's. All the codes went away with no misfires! Yay. Guess a bad O2 can cause multiple misfires! Bank 1 Sensor was an old one covered in soot. Thanks for the advice guys.
Old Jul 30, 2018 | 11:01 PM
redwhitekat's Avatar
Isn't the tick due to slipped liners or looses sleeves ?
Did you do anything about that
Old Jul 31, 2018 | 11:54 AM
328Driver's Avatar
I had a deformed pushrod and associated rocker. 3 bent valves as well. The place that did the head work used to do all the Discovery warranty work. They told me there was a service bulletin LR wanted them to do which involved opening up the valve stem guides I believe since valves were sticking which resulted in bent valves. Anyways the tick I've endured for the last 3 years is now gone. I think everyone runs to diagnose these motors as slipped liners whenever there is a tick.
oilspotLR
Sep 25, 2022 08:14 AM
bcameron70
Sep 13, 2019 02:35 PM
disco2003
Jul 20, 2016 04:59 PM
smount101
Nov 5, 2012 09:15 AM
nycdisco85
Sep 5, 2011 10:31 AM
