top radiator hose junction leaking.
Old Dec 29, 2016 | 05:42 PM
slvrdisco01's Avatar
Default top radiator hose junction leaking.
Hi All
I just pressure tested my cooling system and found a small leak under the three way plastic junction (bleed screw junction) is there a replacement available? Or do I have to buy the whole thing with hoses?
Cheers John.
Old Dec 29, 2016 | 06:28 PM
jamestfl's Avatar
for about the same price as that hose and assembly you can do the inline thermostat modification. have done it on my truck and have steady temps in the high 170's to mid 180's.
Old Dec 29, 2016 | 07:26 PM
Charlie_V's Avatar
I've done the inline mod and highly recommend it.
However, before I did that, my T left me stranded on the highway one day. The fix (which lasted for years and would last a lifetime) was a metal plumbing T with three threaded nipples and three hose clamps. You lose the bleed screw but that's a part that will never, ever, fail. Cost was about 16 bucks plus two gallons of water to get me home.
Old Dec 29, 2016 | 08:45 PM
LR03NJ's Avatar
Originally Posted by slvrdisco01
Hi All
Cheers John.
If you need a replacement immediately you can go home depot for a temporary fix or permanent install.
Old Jan 3, 2017 | 02:11 AM
Rlozano's Avatar
I would recommend a local scrap yard. I have tons in the area and that part is only 5 bucks.
Old Jan 4, 2017 | 03:39 PM
Charlie_V's Avatar
When my T failed, I tried some roadside repairs and it just CRUMBLED. It was ridiculous. I don't like plastic parts. Period. No plastic parts. But the first T did last 15 years...
Old Jan 4, 2017 | 08:09 PM
acg's Avatar
acg
Just hot off the press.... see here:
https://landroverforums.com/forum/di...t-joint-82308/
Old Jan 4, 2017 | 08:21 PM
Luckyjayb's Avatar
I noticed that today to. Looked sharp and should never have to worry about it wearing out
Old Jan 4, 2017 | 08:52 PM
Bom2oo2's Avatar
Take the advice of people that suggest going inline, now that T is broken, you will be very satisfied afterward,
a good replacement T-stats for inline will cost under $10 when need to be replaced, consistent temp's & cooler running engine is the benefit,
(The only downside is you will get tired of looking at temp, because it stays very consistent & never gets to danger zone if you don't have any leaks,!)
AbnMike
Apr 28, 2016 08:17 AM
Tristan Marineau
Jun 5, 2015 07:50 AM
AZRover
Jan 9, 2010 05:51 PM
mattrickman
Apr 8, 2009 10:20 AM
