Tophat block re sleeve?
Old Aug 10, 2021 | 10:46 PM
DodyDisco's Avatar
Default Tophat block re sleeve?
Is it feasible to re sleeve a single cylinder and not have some strange reason you'd have to do them all?
Thinking about picking up a tophat block that only has a few hundred miles on it, and using that to build a fresh engine.
Mistakes were made during assembly and single cylinder is scored/worn down significantly.
Im thinking have a new sleeve/liner put in that cylinder and good to go?
What would you pay for a block or sell one for thats perfect besides the sleeve issue?
Any thoughts? Opinions. Whatever. Thanks.
Old Aug 11, 2021 | 12:07 AM
Richard Gallant's Avatar
@DodyDisco you can for certain replace a single liner, BUT you need to check the piston and bottom end for damage and see why the cylinder got messed up
Old Aug 11, 2021 | 03:15 AM
The Deputy's Avatar
As long as the liner wasn't damage to the point it was worn through, damaging block, like a wrist-pin walked out of piston...it could be replaced. I'd surely check everything else over with a fine-toothed comb though, like Richard mentions, since foreign materials would definitely be a factor for concerns amongst other moving components.
Alan_H
Aug 18, 2017 02:57 PM
acamato
Mar 11, 2016 05:34 AM
mudbug308
Jan 2, 2014 01:55 AM
dynomite
Aug 5, 2011 10:49 PM
DiscoArt
Nov 11, 2009 03:30 PM
