Sponsored by: CARiD
Question about cylinder liner
Old Dec 30, 2013 | 07:13 PM
mudbug308's Avatar
Default Question about cylinder liner
I disassembled the replacement engine i purchased in order to replace head gaskets and every other gasket i could think of. On one of the cylinders, i can see that the sleevie is sticking up compared to all the others to the point where it was embedded in the head gasket. Is this something to be concerned about or should i just roll with it? I spent way too much money on the engine to overlook this and was told it had approximately 70-75kmi on it. Any ideas?
Old Dec 30, 2013 | 07:20 PM
CCRovers's Avatar
That seems like a slipped liner to me. You should either get your money back for the engine if it had any sort of guarantee or pin the liner(s) in place and have the block decked by a machine shop so everything is flat and true.
Old Dec 30, 2013 | 08:21 PM
mudbug308's Avatar
Does anyone on this forum know where i can order top hat or flanged cylinder sleeves?
Old Dec 30, 2013 | 10:23 PM
04duxlr's Avatar
That liner can be pressed back in, all of the liners pinned and the block decked to make sure it goes back together ok. If you want to get flanged liners, you can contact Turner or RPi out of the UK, or try Great Plains Rovers in the US. Machining the block for these liners is something most machine shops may not want to try so make sure you find one willing to do it before buying the liners.
Old Dec 31, 2013 | 10:19 PM
Another grim thought - you may want to do a block pressure test to detect if a crack exists behind the liners. You can rent the pressure test set up, the coolant channels are blocked off and compressed shop air is pumped in. Just to be sure block is worth throwing all these parts at.
Old Jan 1, 2014 | 03:12 PM
mudbug308's Avatar
Who rents the presure tester for the block? I know of a good machine shop near where i live but if i can save myself some time i would like to test the replacement and my original block first.
Old Jan 2, 2014 | 01:55 AM
Zenith88's Avatar
This is my first opportunity to visit this website.I want to show my admiration for your generosity in support of people that should have assistance with your question.
colemtd
Mar 30, 2019 08:57 PM
scarrell
Nov 16, 2012 06:04 PM
mbz22
Freelander
Oct 1, 2010 04:56 PM
pinba1173
Appearance & Camping Set Ups
22
Jul 27, 2009 07:33 AM
