Torque spec on axle drain plugs
Old Oct 24, 2014 | 10:11 AM
chicane's Avatar
Question Torque spec on axle drain plugs
After changing the fluid I noticed a slight leak from the transfer case and front axle drain plug. Nothing major but it needs to be addressed. What is the torque specs for these drain plugs. How ofter should they be replaced? Can you use a coating or teflon tape to prevent these small leaks?
Old Oct 24, 2014 | 10:13 AM
drowssap's Avatar
are you still using the plastic plugs?
Old Oct 24, 2014 | 10:17 AM
chicane's Avatar
Yes, but it is not leaking from the filler plugs it is leaking from the metal drain plugs.
Old Oct 24, 2014 | 10:19 AM
RicketyTick's Avatar
edit: oops! I was thinking the plastic plugs also.
yes you can use teflon tape on the drain plugs.
___________________________________________
and... for fill plugs on the front and rear diffs you can use these,
RovahFarm for all your new Land Rover Parts and Accessories
Rovahfarm
Radiator Brass Plug
Ref: ERR4686B / Price $3.50
Application: Disco I, Defender, Range Rover Classic 92-94 and yes these do fit the D2 diff.
Old Oct 24, 2014 | 10:28 AM
Alex_M's Avatar
yes you can use teflon tape.
But, for fill plugs,
Rovahfarm
Radiator Brass Plug
I paid $12 each for mine :|
Old Oct 24, 2014 | 10:33 AM
chicane's Avatar
So I am looking at the AB video here on service maintenance for the axles on the D2 and if you look closely at the service kit the transfer case fill and drain plugs look like standard oil drain plugs with COPPER WASHERS. My fill and drain plugs on my transfer case look like drain plugs on the pumpkins. They are inverted (square) 1/2 inch plugs. Is that correct?
By the way where did you guys buy your replacement plugs.
Old Oct 24, 2014 | 10:44 AM
On the tc drain and fill yes inverted type plugs are correct, use teflon tape on them.
On front and rear diff drain use teflon tape and I put a link above to a brass fill plug for front and rear diffs/pumpkins to replace the plastic ones.
Old Oct 24, 2014 | 10:55 AM
chicane's Avatar
Cool. You are saying use this for the new fill plugs? Radiator Brass Plug
And do you know the torque specs? for the drain plugs?
Old Oct 24, 2014 | 11:01 AM
Yes you can use those to replace the plastic fill plugs in front and rear.
and don't know not right off hand on the torque. I just tighten those by feel but, if you download and look in the RAVE manual, I'm sure it's in there.
Old Oct 24, 2014 | 12:12 PM
chicane's Avatar
What about the fill capacity? In that video it stated that there was a specific capacity that you had to fill the TC and the Pumpkin and that it wasn't correct to just fill to the bottom of the fill plug. Correct?
