torque wrench
torque wrench
What size torque wrench's is everyone using for engine rebuild? 3/8 or 1/2"..... Want something i can use for everything on the truck baring something that needs something rediculas torque settings.. just everyday stuff and mainly engine rebuilding.. I know click torque wrench is the norm...
Thanks Chris
Thanks Chris
what size bolts? most importantly how much pounds you needing to apply?
i would get a good 1/2 and just use a 1/2 to 3/8 socket adapter if you need it for a 3/8 socket. just be carefull on the size. make sure you can get it in and out of what you need it for. the 3/8 are usually smaller, etc.
________
Mflb review
________
Mflb review
I know that there are a few instances on here where you need 300 lb/ft torque and people sometimes have a hard time finding one that goes that high. There is a pretty cheap one at Harbor Freight that I have seen several people mention buying on here and they have had no problems with it and it has served most of their needs.
The highest torque on a DII is the axle nut at 360lbs. Otherwise you can get away with a 1/2" 25-250lb wrench, though a 3/8" torque wrench is nice to have. The main thing most people need to torque on are lug nuts which a 1/2" wrench is nice to have. Craftsman torque wrenches are terrible junk and only have a 90 day warranty. Look for a gearwrench (USA) clicker torque wrench online or get a proto, CDI, precision instruments split beam for cheap on ebay. Surprisingly enough the harbor freight torque wrenches are also great for $10 and $15, lifetime warrant also.
Lowes has Kobalt both 1/2 and 3/8s for good prices. lifetime on those as well.
________
Threesome Movies
________
Threesome Movies
There's more to a torque wrench than the warranty. Namely, how accurate it is.
I wouldn't put much faith in the accuracy of a $15 torque wrench.
For anything critical, like head bolts, I'd certainly calibrate any torque wrench first.
Also, for head bolts you need a torque angle gauge in addition to a torque wrench.
i agree somewhat..
I would have to agree with you but as for the crappy engineering that went into my engine , i am wondering.. I found this one... Is this a good one? they seem to use in the uk alot ....
http://cgi.ebay.co.uk/1-2-Torque-Wre...ools_Equipment
http://www.mactools.com/product/tabi...431-tm281.aspx
Let me know...
thanks Chris
Looks nasty! That's a good price for a 1/2". They run about 75-100 bucks in the US. Good tool, you will use it alot. Esp for the lug nuts/tires. Thats where I use mine the most.
________
Colorado marijuana dispensaries
________
blmw
Member Group And Special Buys
06-29-2012 02:52 PM
