Torquing Spark Plugs
I'm all set to spend the few hours this weekend to tackle the plug and wire swap on my 04 SE7, but I haven't gone out and bought a torque wrench...yet...
Does everyone here use one for replacing the spark plugs or is it enough to "feel" the 25lbs that they're supposed to be torqued down to?
Yes, I know ideally your supposed to use one, but does everyone use one or is it just strongly suggested to do so...
Sounds good. I'll probably do the same. I used to work on my dirt bike when I was a kid all the time and replaced a few spark plugs...just tightened them down snug and everything worked out...
Done quite a variety of work on cars, but never done spark plugs...
Is anti-seize or a couple drops of oil necessary on the spark plug threads when replacing or just snug them up bare?
Never-Seeze is perfect for spark plugs. I use the Pure Nickle as it resists higher temps (but is more toxic).
![](http://www.bostik-us.com/Images/markets/PNS_W(9qcts3).jpg)
I've also used regular grade which actually works fine.
![](http://www.bostik-us.com/Images/markets/Regular_M(p82ts3).gif)
I use Never-Seeze because it's electrically conductive (not all anti-seize products are).
Correct torque is 18.0-21.6 lb-ft
I usually just tighten another 3/4 turn after the seat contacts the head.
marsyas
02-25-2021 08:11 AM
