Torquing Spark Plugs
Old Nov 11, 2010 | 09:25 AM
Disconoobie's Avatar
Default Torquing Spark Plugs
I'm all set to spend the few hours this weekend to tackle the plug and wire swap on my 04 SE7, but I haven't gone out and bought a torque wrench...yet...
Does everyone here use one for replacing the spark plugs or is it enough to "feel" the 25lbs that they're supposed to be torqued down to?
Yes, I know ideally your supposed to use one, but does everyone use one or is it just strongly suggested to do so...
Old Nov 11, 2010 | 10:22 AM
lipadj46's Avatar
I have a torque wrench but don't use it on spark plugs. I just don't use too long of a ratchet and just get them down snug but not super tight.
Old Nov 11, 2010 | 10:27 AM
Sounds good. I'll probably do the same. I used to work on my dirt bike when I was a kid all the time and replaced a few spark plugs...just tightened them down snug and everything worked out...
Done quite a variety of work on cars, but never done spark plugs...
Is anti-seize or a couple drops of oil necessary on the spark plug threads when replacing or just snug them up bare?
Old Nov 11, 2010 | 10:40 AM
lipadj46's Avatar
People have differing opinions on antiseize on plugs. I use it sparingly but most spark plugs already have an an antiseize coating.
Old Nov 11, 2010 | 11:33 AM
agthird's Avatar
just snug them up don't over tighten them or all hell will break loose...
Old Nov 11, 2010 | 05:58 PM
Good and snug and no anti seize.
I just spray the plug hole with Liquid Wrench before I remove the plug and again before I put the new one in.
Old Nov 11, 2010 | 08:00 PM
antichrist's Avatar
Never-Seeze is perfect for spark plugs. I use the Pure Nickle as it resists higher temps (but is more toxic).
I've also used regular grade which actually works fine.
I use Never-Seeze because it's electrically conductive (not all anti-seize products are).
Correct torque is 18.0-21.6 lb-ft
I usually just tighten another 3/4 turn after the seat contacts the head.
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
Externet
Sep 10, 2012 06:46 PM
ITMagician
Jun 12, 2006 08:37 PM
2002DiscoII
Jan 13, 2006 12:29 PM
