tow package cost advice
Old Dec 21, 2008 | 07:28 PM
AK Rover's Avatar
Default RE: tow package cost advice
Actually Spike, he is looking to go the other way, 4-flat to 7 round.
There are 7-round plugs that you simply plug your 4-flat into for your lights, turn signals and ground then you just need to run wires for your battery charge line, brake signal to activate your brakes and reverse lights if you want to them. I actually had to do that with my dodge when I added the factory 7-round plug. Pepboys, Napa or Autozone should all carry the plug set up you need.
Old Dec 21, 2008 | 07:36 PM
Yeah, thats what I meant. I have the adaptor to go from a flat four on the tow vehicle to a 7-round on the trailer.
I bought it at the store, $12 I believe.
Old Dec 21, 2008 | 07:54 PM
DanR's Avatar
ah thanks spike, but i need the trailer brakes so what other options do I have?
Old Dec 21, 2008 | 07:59 PM
I figured that you did need the trailer brakes.
If you call Atlantic British they can point you in the right direction.
There have been others with the same problem and they did get what they needed, trailer brake controler and wire harness.
MiDisco2
May 28, 2014 08:53 PM
96redvettelt4
Feb 22, 2014 11:26 PM
MinneapM635
Jul 5, 2012 12:45 PM
oysterhead
May 25, 2010 09:55 AM
The Champ
Jun 17, 2007 11:06 AM
