Towing with a lift 1,000 miles?
Ab harness should work well. I've heard good things.
Get as much drop as you need for the trailer to sit level. I've got a 4" drop recover I think, which my standard 2" drop hitch goes into. You'd probably do well with a 5" drop hitch, but if you can just wait and see how much drop you need compared to the trailer.
You can always get one with an adjustable drop that way you can adjust it after you get the trailer loaded and see how it sits so it can be a bit more level. I have one that I use because I tow different trailers depending on the games and locations. One sits higher than the other so it makes for easy adjusting.
Have a look at etrailer.com they have some good options, and prices on adjustable ball mounts and other parts> https://www.etrailer.com/dept-pg-Bal...all_Mount.aspx
http://harborfreight.com/8-in-1-adju...not%20provided
This one will handle 5,000lbs and adjust 11 inches down. Also dirt cheap. You still need to get the correct size ball for the trailer.
