towing in low range...safe?
Old 05-22-2008 | 02:40 PM
NiteTrain's Avatar
Default towing in low range...safe?
Land Rover says the discovery towing capacity is 7,700lbs in low range. Now my question is if it's even safe to drive on the highway in low range? What is the top speed you can reach?
Old 05-22-2008 | 02:41 PM
Urban Panzer's Avatar
Default RE: towing in low range...safe?
The question is why would you want to tow in low range ??
Old 05-22-2008 | 03:38 PM
NiteTrain's Avatar
well I have a friend that has a very heavy duty trailer and that plus the weight of my Jeep would really be pushing if not over the 5,500 lbs towing capacity. The place we go off-roading is about 7 miles away so If I could tow in low range and reach a speed of 35mph I would be happy with that.
Old 05-22-2008 | 04:38 PM
nzoliver's Avatar
And....40km/h is about max speed[>:]
Old 05-22-2008 | 05:08 PM
NiteTrain's Avatar
ORIGINAL: nzoliver
hmm that would be too slow..I would probably get ran over on the road.
Old 05-22-2008 | 05:32 PM
Go weight the trailer and then you will know. High range with a 5500# trailer is fine as long as the trailer has brakes.
You never run in low range out on the road unless you are in snow or mud and driving slowly.
Old 05-22-2008 | 07:15 PM
The disco towis rated at 3500kgs, so 7700 Lbs, so you will be fine as long as its braked like Mike said.
heres mine (TD5)towingMy D1 V8 150 miles home
Old 05-22-2008 | 08:00 PM
Disco2Guy's Avatar
U.P., what do you do with the D1? Looks like you're throwing everything at the D2 for your trip to Africa. That's where you're trip is taking you later this year right?
Old 05-22-2008 | 08:17 PM
If you tow in low range at 35 mph you will be at about 5,000 rpm. Do you really want to run your trk at that rpm for 7 miles?
Old 05-22-2008 | 08:39 PM
NiteTrain's Avatar
Mike, what will it damage in the transfer case if you do run on a hard dry surface in low range? I thought full time transfer cases could handle it as long as the CDL is not enguaged.
ORIGINAL: Spike555
spike, I said IF I could do 35mph I would be happy. It sounds like 35mph is not possible so I will not attempt. Yes, the trailer has brakes. I wouldn't pull a vehicle on a trailer that didn't have brakes. This reminds me, who makes a good in cab brake controller for discos?
Quick Reply: towing in low range...safe?
