towing weights
Old Oct 22, 2013 | 09:56 PM
FlyingZebra34's Avatar
Default towing weights
I have the factory hitch installed and am looking to get a travel trailer for long term work trips vs staying in a motel. I was wondering how much weight I can pull and how easy it would be to wire up trailer brakes or if the rover can brake without the assist.
Old Oct 23, 2013 | 07:34 AM
acamato's Avatar
Depends upon DII loading and suspension. Look in the owners manual (avail in the RAVE).
Trailer w/o brakes 1650lbs 115lb tongue
trailer w/ brakes 4410lbs 330lb (710lb in DII/ 900 for SLS)
trailer w/ brakes 5500lbs 385lb (450lb in DII/ 600 for SLS)
Old Oct 23, 2013 | 10:47 AM
What sort of tongue weight and trailer weight are you look at?
You will want to replace the rear coils and all 4 shocks to a more H.D set before towing.
Old Oct 23, 2013 | 02:13 PM
I'm running OME 2" HD lift right now so I don't think it'll bottom out but I might up the springs a bit To compensate for the weight.
Looks like I'll be installing trailer brakes though
ajh
May 15, 2007 08:19 AM
okdiscoguy
Apr 18, 2007 06:15 PM
Benhamtroll
Jul 22, 2005 12:31 AM
sixpack
Jul 5, 2005 04:41 AM
listed
Jun 12, 2005 06:57 AM
