TPS Replacement
Old Sep 26, 2024 | 02:05 PM
MRGMAN's Avatar
Default TPS Replacement
Hi All, I just purchased a TPS for my 04 Disco II. Afterwords I started it up and it was idling too high. Is there a secret step I don’t know about. I did it because Google said if you have a 4th gear incorrect ratio CEL that a faulty TPS could cause it. Thanks
Old Sep 26, 2024 | 06:03 PM
JohnZo's Avatar
Secret step is to reset Adaptive Values in the ECM. Needs an electronic tool connected to the OBD port. Putting the old one back might solve it, or it might also rev high if it changed position a little.
Old Oct 5, 2024 | 10:30 PM
MRGMAN's Avatar
Default TPS/4th Gear Incorrect Ratio
Hi All,
I was told that I needed to put the truck back to stock “adaptive values” so I purchased the Launch Elite to do so. Well either I’m stupid or the instructions suck, or both! I can’t figure out how to do it. Is there anyone out there that is familiar with this tool that would be willing to help (pretend I’m a pre-schooler) 👶 Thanks in advance.
Old Oct 6, 2024 | 03:02 AM
longtallsally's Avatar
Originally Posted by MRGMAN
Hi All,
I’m not familiar with that tool, but have done it on a Nanocom. If you google how to do it with a Nanocom, you might be able to figure it out.
However, my suspicion is that is not your issue and instead may have a vacuum leak somewhere.
Old Oct 6, 2024 | 07:22 AM
JohnZo's Avatar
Here's what I do: I did not buy a special device, rather use my Samsung tablet running the GEMS Lite app. That app has a feature to Reset Adaptive Values. Takes about a minute or less. The tablet communicates with Bluetooth to the OBDLink LX dongle I use to plug into the OBD port. Sorry, I don't know about Launch Elite.
PS Sorry my truck is a D1, forgot this is for a D2.
AVLDefender
Feb 6, 2026 08:38 AM
jmha106
Jun 27, 2016 08:27 PM
drowssap
Feb 10, 2012 08:08 AM
LCollins1990
Feb 3, 2009 05:09 PM
JBEGIN
Dec 10, 2008 05:37 PM
