TPS Test
Old Oct 15, 2009 | 05:23 PM
kenk's Avatar
Default TPS Test
Is there a way to test a TPS before I go replacing it? Like maybe a simple resistance measure? I'd look in rave but I'm at work tonight.
Old Oct 16, 2009 | 03:11 PM
tweakrover's Avatar
i would like to know also
Old Oct 16, 2009 | 03:21 PM
kenk's Avatar
I looked in the rave manual, all it said was it was a variable resistor, with voltage output of 0-5v
Old Oct 16, 2009 | 03:27 PM
tweakrover's Avatar
so i imagine if you put an ohm test on it you could see the resistence change as you turn it, the only thing is we have no idea what the parameters should be.
Old Oct 16, 2009 | 03:33 PM
NiteTrain's Avatar
heres a video for testing a TPS on an older GM vehicle, but procedure should be the same
http://www.youtube.com/watch?v=IsX5q3jBeBQ
Old Oct 16, 2009 | 07:05 PM
alanroberts50's Avatar
If I recall RAVE says that if it goes out of parameters then the check engine light should come on but it sure didn't on mine. 98 D1
Old Oct 16, 2009 | 08:50 PM
kenk's Avatar
Yea, I read that in there too. I thought it odd that something isn't right and making it idle that high, yet the ecu dosen't realize it and trip the CEL. Well, I got a new one on the way, hope thats it.
BloodyShirt
Mar 25, 2015 12:08 PM
Savannah Buzz
Dec 8, 2011 07:12 PM
alpinab7
Aug 17, 2006 09:54 AM
discovery125
Apr 7, 2006 04:27 PM
