tracking down elecrtrical draw kiling Battery
Old Jun 27, 2020 | 06:09 PM
dparham's Avatar
my condenser fan is working and I even replaced it recently, but maybe Ill aso look there for the current draw... i know im CLOSE to a cure but dang its coming from al directions! lol
Old Jun 28, 2020 | 12:14 AM
redwhitekat's Avatar
Well most cooling components run when it’s idling or running. So everything shuts off when key is out.
Does your ultraguage stay on when you turn off ignition ??
Old Jun 28, 2020 | 12:16 AM
Could have a bad battery just nearly holding charge. Of course your going to see 13.7 14 volts when alternator is pumping out voltage.
Old Jun 28, 2020 | 09:56 AM
dparham's Avatar
no, everything shuts off and only if a/c has been turned on does it draw on battery considerably and drain battery ... if I dot use climate control unit it runs fine no issues at all.. except south Florida summer issue lol
Old Jun 28, 2020 | 10:04 AM
dparham's Avatar
i had an optima for a few ( 3 ish) years and one day it didnt start... i have an optima charger so took it out and placed a brand new battery about a year ago and was working fine for about 8 months and then one day it just started draining and I died on side of road... ( i was sure alternator was a cuprit as no matter a/c or not it would not charge battery.... replaced the battery with my original optima which the optima charger said was in good condition and had been on trickle charge all that time... car ran great until i turned on a/c then died... i recharged the other "newer" battery and charger said it was also fine and replaced that... car ran great no issues.. til i tried a/c and car started draining and wouldnt start soon after i turned it off at my short destination... , so jumped it, came home without a/c no problems and took it out and replaced with original optima which has been in there for a month with no issues... but I fear not to turn on a/c as it will tank battery again... also i did test this optima with a/c one last time and it tanked it.. took it off brought it inside and recharged and took it back out and thats when I didnt use a/c and all is fine... so its related to A/c seemingly and when looking at ultragauge it alwasy shows 13.8-14.2 charging range and battery is fine ... hope that made sense lol
Old Jun 28, 2020 | 11:15 AM
definitely a weird issue
I would start by taking a multimeter and checking across fuses relays etc anything related to the climate control ac system etc see what amps are going across draining it.
You probably need a good meter that reads milliamps. You should be able to pin it down pretty quick
Old Jul 1, 2020 | 08:56 AM
dparham's Avatar
yeh thats next step.. I have a FLUKE that reads em... looks like its time to spend some time with it lol. I was hoping it was a common issue and not a complicated trackdown... lol
Old Jul 5, 2020 | 12:02 AM
dparham's Avatar
waiting on my replacement DMM-11A Bussman fuse for my FLUKE multimeter lol then im going to do some serious wire tracking.. i did notice my blower a/c/heater wires were very hot when i turned on a/c.. i was reading about 12.3v but at battery was 14 ish so alternator was bring back the voltage to battery... however maybe too many amps hitting a failing blower motor? wil be checking maybe tomorrow.. i do see a drop spike in volts on ultragauge when i turn the different fan levels on manually from climate control.. i did order a replacement motor just in case thats the culprit... also did a load test on my red top optima battery i took out for a full charge... it sits at around 12.7v on the optima charger and occasionally shoots to 13.. not sure if that is ok.. but the load test simulating an engine start dropped my voltage with meter under 12v, so maybe its a complex issue of things... maybe when alternator went south it killed my just new battery ( which is now back in disco and is fine as long as ac isnt used... and my old optima (4-5 years old) is on the maintainer for a backup... it works as long as a/c isnt used... that with a bad blower motor... hmmm
Last edited by dparham; Jul 5, 2020 at 11:02 AM. Reason: had Typo, said 11v drop but was just under 12v
Old Jul 5, 2020 | 12:49 AM
Yup sounds like something going on with your hvac motor wiring etc. Wires shouldn’t be hot. Check wiring maybe it’s grounding itself. Bare or burned wires somewhere and like you said bad motor. Unplug motor and see if issue goes away
Old Jul 9, 2020 | 08:31 AM
dparham's Avatar
if its not too hot today here in south florida and raining im going to check the motor wiring i do have a burnt wire i replaced a few years ago when fan stopped and inrepaired and all worked for a few years but always noticed wires kind of hot and now real hot and burned looking again plus fan never has blown nice.. blown ok but always felt lacking ...
