Tracking down a misfire with no codes
Ok, Like I said no codes.
Already replaced wires with the magna cores, running ngk iridiums.
-no vacuum leak
-no arcing
-compression test yielded no valves sticking
Getting really sick of this truck. She's never failed me but dear lord the little gremlins are enough to kill you.
The scanner is showing maybe a problem with 1 2 and 8 cylinders when we watch the data while she we running. Any ideas?
-no vacuum leak
-no arcing
All engines have a "stumble" at a hot idle, usually not noticeable but a broken or worn motor mount or like you said a bad harmonic balancer can make it seem worse that it is.
If your check engine light works and you are not getting any codes then there is no problem.
If there were a problem it should show up within 400 miles, the worse the problem the sooner it sets off the check engine light.
