Foam strip for ventilation air intake
Old Jul 15, 2010 | 12:19 AM
discoboy's Avatar
Default Foam strip for ventilation air intake
For those of you who have replaced or installed a foam strip over the ventilation air intakes on these trucks, what have you used other than the dealer foam-which is very expensive. I need to replace mine but would like to know what aftermarket foam/insulation has worked.
Old Jul 15, 2010 | 01:25 AM
yloDiscoII's Avatar
I'm guessing you are talking about the vent in between the windscreen and the hood?
If so, I used portable A/C unit filters that you can get at most hardware stores, just cut it into strips to fit.
Old Jul 15, 2010 | 11:39 AM
janderson41's Avatar
Default foam strip
Hello from Scotland.
In the UK there is a TV sales channel QVC, which I think is in the USA also.
Whenever they post purchases in the UK they all have foam packing strips for protection inside. Each strip is 6"long by 1" square and fit perfectly inside the intake.I used them in my Discovery 1 and they are super.Ask among friends who buys from QVC and get the strips.Hope this helps.Best part is they will be FREE.
cheers
Jim Anderson Discovery 1996 300Tdi auto(Jap reimport)
Old Jul 15, 2010 | 08:41 PM
I had done a write up on this a couple of years ago.
Before.
What to buy at Home Depot.
Cut to size.
Staple together.
Done.
Old Jul 15, 2010 | 11:32 PM
discoboy's Avatar
Thanks for the tips, I figure we really need it when we are on dusty roads or when wheeling, some filter is better than nothing.
Old Feb 15, 2012 | 07:46 PM
Colin Haycock's Avatar
Smile
Ref Discovery 2 - Foam strip for ventilation air intake (replacement)
My foam had all but crumbled away, and non of the local air conditioning providers could help, let alone the Land Rover dealers!!!
I found that dish washing scouring pads (green things) available from supermarkets work a treat. Simply cut to size and slot in. Cost? AUS$1.15.
And all but indestructible.
Job done!
Old Feb 15, 2012 | 08:01 PM
rimasco's Avatar
is that intake for the cabin?? I need to replace as well
Old Feb 16, 2012 | 07:11 AM
bearcatfans's Avatar
Not expensive at all. Just order this one and install. Takes about 3-5 minutes. Done.
Filter Pollen (Genuine Part # JZL100120) - Land Rover pcv & pollen/cabin filters from Atlantic British
-aaron
2003 SE7 125,000 miles
Old Feb 16, 2012 | 08:13 AM
creepin's Avatar
Thats nuts this thread just came up because I noticed yesterday mine is starting to crumb away..I guess after 8yrs its ok..
Old Feb 16, 2012 | 08:46 AM
jafir's Avatar
Replace it soon. It will get sucked into your blower motor.
