Traction control
Thanks for the replies. No ABS light on and no Traction Control light flickering, that was what I first noticed this weekend. I'm familiar with the wheels spinning a bit then hearing the system engage and the TC indicator light come on. My wife has been driving truck the last few months so I am not sure how long this has been an issue. Changed brake fluid late 2010 early 2011
Ok . . . ABS, Hill Descent and Traction Control lights all come on for a few seconds then go out, at start up of engine. Checked fuse panel in truck for Gear Box, that was fine; checked ABS fuse, that is fine, too. Checked fuses under hood and nothing bad there. Would pulling the codes narrow this down? I have been using a local non-dealer mechanic group for several years, only Land Rover, BMW repair shop and they've done well by me. Just wondering if I might figure this out on my own before having to fork over $ to them... thoughts?
on
I didn't see you mention anything about codes before.
When you say the 3 amigos come on for a couple of seconds, are you referring to when you turn your key to the 2nd. position and all the other lights come on?
If you have and codes, go get them read a a local parts store, most do it for free, and get the exact fault numbers so we can figure out what is happening.
gamecockdisco
07-12-2010 08:34 AM
rodrick smith
04-13-2007 06:09 PM
