traction control hill decent abs
Old Nov 11, 2005 | 01:39 PM
tonyzp007's Avatar
Default traction control hill decent abs
how do you guys reset this feature ,i was driving this morning and all of a sudden all these lights came on ,what do i do to get them removed?
Old Nov 13, 2005 | 06:12 PM
messias's Avatar
8th Gear
Default RE: traction control hill decent abs
Hello there,
The question is not how you can remove them (Dealer)... Is WHY did they lit up!
Sensor malfunction..?!
ABS module "burned out"...?!
Either way, get to the dealer "asap".
Best Regards,
Messias.
Old Nov 13, 2005 | 06:53 PM
Randy Lover's Avatar
weve had ours light up 3 times, thats why weve just sold our car yesterday because the warrenty is nearl up and we dont want to pay £500 everytime it goes wrong, also to get round a corner today my dad had to climb up a normal sized curb and the traction control came on twice for no reason, also the tempreture gauge shot up, it may only just be mine but if it happens on anyone elses please let me know
Old Nov 23, 2005 | 06:47 PM
Beachrover's Avatar
6th Gear
Could be many things but you will need to get the codes read before you will know exactly what it is.
Could be bad brakes, rotors, hubs, ABS sensors, modulator, shuttle valve but no real way to know without first having codes.
Old Dec 17, 2005 | 11:35 PM
Sigma3's Avatar
7th Gear
hello I just bought an 02 from my girlfriends sister. it too has the three lights on. I was informed that adding break fluid will make them go out i have not tried this yet.
Old Dec 18, 2005 | 07:25 AM
to my knowledge brake fluid will make no differance to the lights
Old Dec 18, 2005 | 03:37 PM
mikemeyer0's Avatar
those lights are very common check the net, you will see that everyone has these lights light up, dealer does not know what the problem is, they have to go thru a series of checks and usally runs people 5-7 hundred bucks. start with ABS system, like wheel sensors, mump, thats where most of the problems are found.
Old Jan 29, 2006 | 01:22 AM
katbri's Avatar
We had ours light up on our 2000 Disco II and the dealership said it needed front brakes, $500 later...problem solved. They can do a quick check at the dealership to tell you what it is.
Good luck!
tonygallagher
Apr 23, 2018 10:26 AM
gamecockdisco
Jul 12, 2010 08:34 AM
gsgtsg
Dec 3, 2008 08:41 PM
dsmtrain
Jul 12, 2008 07:15 AM
dgd
May 16, 2005 03:58 PM
