Traction Control Override???
Old Jan 17, 2013 | 11:45 AM
DROVER1984's Avatar
Default Traction Control Override???
Hey all!
I have a 02 Disco 2 and was hoping someone could enlighten me on if you can override the traction control, specifically in 4WL. I don't mind having it active in 4WH, but I find it very aggravating in 4WL to have the traction control kick in. Any thoughts???
Brandon
Old Jan 17, 2013 | 11:52 AM
ZGPhoto's Avatar
Step 1: Drive it for a few months
Step 2: The 3 amigos will come on
Step 3: You'll have power to 1 wheel when you lose traction and go nowhere
Step 4: ?
Step 5: Better offroad capability.
Old Jan 17, 2013 | 12:03 PM
jafir's Avatar
Originally Posted by DROVER1984
Hey all!
Brandon
You'll get stuck. I assume when you're in LO that you are off-road or doing something else that is at least a little aggressive. The transfer case in your D2 doesn't lock, so if you lose just a little bit of traction, one wheel is going to spin and the other 3 are going to do nothing.
Last edited by jafir; Jan 17, 2013 at 12:04 PM. Reason: I meant other 3 wheels... but I guess the spare doesn't do anything either.
Old Jan 17, 2013 | 12:11 PM
binvanna's Avatar
Hey all!
Why is that?
Old Jan 17, 2013 | 04:22 PM
nychaze's Avatar
Like the others have said you most likely dont have a locking CDL, what you have is All Wheel drive (power to 1 wheel) with High and Low range gears. You would need to add a lever to engage the CDL or change out the front output housing. I dont know if the 02 came with the CDL without the lever or without the housing... 03 came without the hosing.
The traction control is sensing the single wheel spinning that has power and tries to brake it causing the power to transfer to another wheel.
Does your lever only have a H-N-L on it and only move forward/backward? or can you move it side to side and forward/backward the patern is as follows:
Front of Truck
Locked - Unlocked
L - L
N
H - H
Rear of Truck
Old Jan 17, 2013 | 09:14 PM
ZGPhoto's Avatar
02s didn't even have the CDL nipple, ask me how I know... New t-case and aschroft linkage later, it now has CDL.
gamecockdisco
Jul 12, 2010 08:34 AM
rodrick smith
Apr 13, 2007 06:09 PM
ny1999
Mar 4, 2007 05:46 PM
OzRRS
Mar 29, 2006 11:16 PM
Rob
Oct 6, 2005 11:48 PM
